115evinrude
- Joined
- Oct 8, 2009
- 10
I bought a New prop and i wanted to test it yesterday on the lake. the motor started ok however was ilding high so i adjusted the idle. when i pushed the throttle i had problems.
The throttle was kind of stiff when pushing it foward. when i pulled it back to go in reverse it had no problems. while trying to go foward it would go but would go very slow. when i pushed the throttle all the way the motor would stall. I looked at the throttle cable while pushing the throttle down and saw that the bracket holding the calbe would push out away from the cable. the nut holding this bracket was tight.
I worked on it lastnight but cannot fix it. like I said when i pull the throttle to go in reverse it work fine. but to go foward it is stiff.
How can i fix this?
How can i fix this?
