Throttle question
shaunknee
Hi
New to the forum. I?ve purchased a ?91 25hp Mariner tiller. I?ve changed the thermostat, impeller and plugs. The motor is in good shape. The only question I have is regarding the throttle. I figured the throttle should return once you let go of the tiller handle, however I don?t see and return system. The 2 springs on either cable cam seem to counter act each other to maintain cable tension. Is this normal for a Mariner/Merc ?
Thanks in advance
shaunknee
Re: Throttle question
Maybe someone with a 15/20/25 merc/mariner could leave a quick post about their tiller throttle.
Thanks
