lakeman1999
- Joined
- Apr 20, 2003
- 550
Hello, I made a search, using throttle response, and received 107 hits on messages, but found none seemed to fit my problem. Have a "94" Johnson 40 two cylender twin carbs that first time in water in probably three months (with freshly mixed fuel, auto oiler has been disconnected, and oil feed line plugged) the motor will not run at full power unless the choke knob is held in. Have sprayed carb cleaner thru carbs, and seems to help, but still will not run at speed. Thanks in advance for any help for a new member of the forum.
