I can't see why not? they have the notches for the "old force) and not a bad price either3300 Xtreme Control Cable 9' - SeaStar Solutions CCX63309 - iboats.com
3300 Xtreme Control Cable 9' - SeaStar Solutions - Since 1998, iboats is the most trusted water lifestyle online store for boat parts and accessories, boats for sale, and forums. Enjoy great priced products with fast shipping.ww2.iboats.com
Found these on this site.....will these work?
I do not think so as long as you know for sure the old and new cables are of the same length and installing the connectors at the same length also. If any it would just be a minor adjustment which you should start with the cables first instead of the shift shaft.Thanks Nordin....the old ones look good to me. If I put these new cables on exactly the same as the original ones, do you think I will have to adjust the shift shaft setting?
Thanks.....took your advice about starting with the cables first for making any adjustments, did not have to mess with the shift shaft setting at all. Still need to get on the water and make sure the throttle cable is adjusted right....looks good doing an engine off full throttle.....kinda hard to do it for real on the garden hose/muffs. LolGreat and thanks for letting the forum know how it went! Enjoy!!!
