Re: Throttle Sitcks?
Remove throttle cable from engine, remove spark plugs, spin prop and put engine into forward gear.
Now, slowly advance the throttle linkage by hand where the throttle cable would normally connect. Observe closely all operations pertaining to the throttle and timing, that is the armature plate under the flywheel, the linkages leading from the armature plate to the throttle cam roller, the throttle butterfly, etc.
Something is apparently sticking..... just a matter of locating the problem area.
Pertaining to the throttle cam actuating rod that leads from the armature plate to the throttle cam roller...... that has a critical adjustment as follows.
(Synchronization Of Older 2 Cyl Engines)
(Such As The 28, 33, 40hp Etc models )
On the linkage that runs from the armature plate (the plate the coils & points set on) to the carburetor throttle roller, loosen the set screw on the brass collar that you see there and temporarily move it away from the armature plate/vertical throttle arm clevis (clevis is that thing the linkage rod slides through). We'll refer to that vertical throttle arm/armature plate clevis simply as the "clevis" from this point on.
Look at the cam that's attached to the front of the armature plate.... the cam that slides up against the carburetor throttle roller. You'll notice that there's a scribe mark on it. The carburetor roller should contact the cam and just start to open the throttle butterfly when that scribe mark is dead
with the roller.
With the engine in gear (not running of course) have the armature plate advanced all the way (by hand) so that it is up against its stop. Now adjust the brass collar (set screw) on that associated linkage rod so that it is up against the clevis. It should be adjusted so that there is either no play, or just a hairs play between the collar and the clevis.
At this point, the armature plate movement is not advancing the throttle butterfly via the rod movement, but further movement of the throttle control, although the armature plate cannot move any farther, causes the tension spring at the armature plate to allow the vertical throttle arm to move farther which now advances the carburetor throttle butterfly via the rod.
If all else with your engine is as it should be, that should do it.
