I have a 69 johnson 85 hp that was stalling when trying to bring it up to WOT but ran excellent if i didnt. That turned out to be dirty jets so i rebuilt the carbs. The problem is when kept under half throttle it doesn't die, but was a pain in the *** to settle it down in to neutral to shut off the engine, it frankly doesn't work. I end up having to turn it off in gear because im afraid i will over extend it and jump into reverse trying to "find" the neutral posistion which i had a near miss last time i tried.
I have brand new throttle cables.
Never messed with the linkage.
Could I be missing some sort of spring to help it retract into posistion?
Do you think it just needss some oil?
Thanks for any help
Thanks for any help
