Thru Hull Exhaust
Status
Not open for further replies.
samm835
Can someone help me with the decision on doing a thru hull exhaust? My first question is is it expensive? Two how hard is it? Thanks for the help and sorry if its in the wrong forum.It has the mercruiser 260HP with an Alpha one drive.
starsnstripers
Re: 84 Century Fiery
I see you have the boat and yr i meant what eng and drive?
samm835
Thru Hull Exhaust
I have a mercruiser with an Alpha one drive I/O, I am wanting to do a thru hull exhaust. Can someone tell me if this can be done at home( I know my way around a shop-some). Also if I take it to a shop how much roughly could i be looking at the damage to my wallet? Anyone have experience on doing it themselves please let me know, just curious on how it can work and the cost. Thanks
bjcsc
Re: Thru Hull Exhaust
Why would you change to thru hull?
John_S
As already posted, the main increase is noise. Many places have restrictions on that, so check your state and boating area. As far as hp gain, it will only be minor in a SB V8 (10hp?) and not much more in a BB V8.
As for how hard it will be to do it, it is going to depend on your engine compartment access and transom. Many people have done this DIY.
If you would prefer some additional noise, only on plane, consider changing to an exhaust tube bellows.
Ayuh,....... Or Less........
As noted,..... The only thng that Increases is the Noise..........
Google up Gilmarine or one of the other offshore boat parts houses for the Pricing Factor.....
MikDee
Banned
samm, I'm not gonna jump on the bandwagon, and say noise, because I'm sure you've figured that out, and it is a subjective thing, some people like it, some don't. I've done it on 2 different boats in the past, one had a 305/228hp, and the other had a 350/260hp. The advantages, I did notice a cooler running engine, never over (140-160*), and more oil pressure, plus I always could see if I was pumping water! and a minor boost in HP, but you're not gonna be able to sneak up on anybody,,,lol,,,and think twice before idling down a canal in the wee small hrs of the morning,,, or otherwise, be considerate. The 305 I didn't bother putting mufflers on, but the 350 definitely needed mufflers, I put on these all rubber mufflers, with slight baffling in them , don't remember the name? but they were great, they mellowed it down like glasspaks. Wait, I think they were Salisbury mufflers?
All I did was take off the hoses on the risers, and marked the transom inside by running a coupla straight lines from the top, bottom, and sides, of the riser elbows, to the transom, (checking, & rechecking the measurements) till I was sure it was good, then took a 1/4" bit, and drilled a hole through the transom at the exact center inside, then took a hole saw (of the proper size to fit your tips into,) about 3", and drilled it thru from the outside, slipped my tips in using 4200 as a sealer, then screwed them down, and went back inside to measure how long a piece of 3" exhaust hose I needed to fill the gap, and using some engine oil, put the hoses on, One important issues is, you must use 2 hose clamps at each end, making it redundant, for what I heard was Coast Guard regulations! The rubber exhaust hose will help quiet it down some.
On some installations, you may need to put 3" high, or higher spacers, under the riser (elbow) before you begin anything,,, I had to do this on one of my boats, don't remember which one?
Mkos1980
I plan on doing this in the spring with corsas Q&Q but I plan on running the mufflers as well. I also dont like LOUD but have heard some boats that have had it done right with corsas mufflers and they sound good. Nice rumble to them, but when in the morning or restricted areas it can be put back through the y pipe.
Zetman
Can this be done with a Merc inline 6? Just wondering
Mkos1980
Yes, but would probebly sound horrible.
MikDee
Banned
That sounds like a "Silent Choice" system a good idea if you got the dough to invest.
And Zetman, Why not?
I had an 86'-22ft. Celebrity Cuddy Super Sport with twin 4.3 OMC Cobra V6's that had thru hull exhausts from the factory, but they were under the waterline, with ordinary rubber flapper covered type fittings. This actually had a nice sound to it, just like an old fashioned inboard boat.
Actually on smaller 6cyl., and 4 cyl. engines, with thru the prop exhaust, you may actually lose power doing this.
rodbolt
first question is what are your local noise regulations?
second is WHY?
Your not going to get any performance gains.
its loud and almost as obnoxious as some motorcycles.
the exhaust on your current set up is more than adequate.
Haut Medoc
What he said^^^^^^.......
It sounds cool for about five minutes....;)
(This is variable, the more gold chains you have, the longer it sounds cool)......:)
Ayuh,.... While ANYTHING is Possibe,.......
The Problem would be,...
The Riser points Straight Down into the downpipe,.....
On the V-motors the risers point aft,+ only slightly downward......
MikDee
Banned
True, the V6's, & V8's with the late model center riser manifolds are the only ones this can be done with. My OMC V6's had those odd "batwing" style manifolds as orig. equip. I had to replace one, it was a b*tch to find! and not cheap.
seafox 257
It sounds gooood! I have a checkmate with a 496 in it and it is loud! and I love it!
HT32BSX115
I had Corsa Capts Call diverters ( and still have) thru hull rear exhaust on my Liberator. (although it's not connected to anything now)
When I had the wunnerful 460 King Kobra 460 installed I used them once in a while. All they did was make a LOT of noise.... there was no increase in performance.
After I put the 454 in I did not reconnect the Capts Call. I probably won't until I hear one with decent marine mufflers.
I like the sound of a nicely (water) muffled V-8. I do not like the sound of straight exhaust and neither does anyone else that rides in my boat.
I would only re-install the Capt Call using some form of marine mufflers. (and I already have holes in the back......if I didn't already have the holes in the transom I wouldn't waste my time....)
Status
