jkimball
- Joined
- May 14, 2013
- 220
Does anyone have any pointers or tips for how to replace a thru hull that I can't get to the inside of the hull?
I have the white plastic thru hull fittings that are above the waterline and I noticed today while cleaning the boat the one for my bow ski locker drain broke off.
I can't seem to find a way to get to the inside of the hull short of separating the hull halves or cutting an access panel and putting a deck plate on there. Neither of which is ideal for me. Now, I don't typically put anything wet in these lockers so, I wouldn't be opposed to blocking or plugging this hole but don't even know that they make a suitable block off plug or cap that I could use.
Any recommendations?
Thanks in advance. I really want to get this boat back on the water and granted, this is technically above the waterline, its low enough I don't think I'm comfortable in trusting that water won't get in
