Thru-Hull Suggestions?
westwon
Hi All!
Trying this for the first time, so please bear with me if I screw it up.
I need to get a fuel line and two alternator lines for my kicker through my transom, and due to the transom design, I can only put the hole about a foot off the water. What is the best solution to get the lines through and keep the water out?
Thanks
Steve
paulie0735
Re: Thru-Hull Suggestions?
Welcome to iboats, hate to answer a question with a question but why do you want to put holes in your boat, what’s wrong with passing them over the top? I would fit quick release fittings and only connect when you’re going to use it.
