thru hulls
piers
I have replaced all the thru hulls on my boat.Bronze below the waterline and marelon above.I am down to my last one which is a drain for a bait well.It connects to a 1 1/8 in. hose.The problem is that the marelon replacement for the 1 1/8 has a thread size of 1 1/4.The hole that it fits into is 1 3/8, so its a little loose.The less expensive and less quality 1 1/8 thru hulls have the correct 1 3/8 thread size.I want to use the marelon, but just wondering if there is something I am missing if I use it even though it is a little smaller than the hole size.I figure between the sealant and tightening up the nut it should not be a problem.<br /><br /><br /> 2600
tashasdaddy
Re: thru hulls
i think you will be OK. it suppose to have water in the live well. use lots of sealant. and make sure it is tight.
Re: thru hulls
Ayuh,......... The Bedding Compound will take care of that little bit of Slop......
piers
Re: thru hulls
thanks guys for the replys....what do you guys think the life is of a thru hull constructed of acetal?The ones I replaced were all white plastic,except for the below water ones, and they were pretyy much shot.the boat is now nine years old.<br /><br /> 2600
