I pulled off the prop to look for model #. I found the nut way below the 50 ft/lbs torque in the merc book. I did not think to check for wiggle before I removed it. The thrust washer and prop shaft have some galling. Size of spot is about 1/16th on both. Should I clean up and regrease and retorque to spec or are they both toast?
18ft 1982 ranger 150 V150XR. Cannot plane up and checking for correct prop (among many other things)
As always
Thanks
Cindy
As always
Thanks
Cindy
