Thrust Washer
flybuddy
Replacing the stock prop on a F115 Yamaha outboard with a Stiletto. Suppossed to reuse the thrust washer but am not 100% sure if the coppery looking raised section in the attached photo is actually the thrust washer. (couldn't get it off). Can anyone verify if it is indeed the thrust washer..thx much
flybuddy
Re: Thrust Washer
pic didn't seem to take--I'll try again resizing it
Dhadley
Re: Thrust Washer
Yes, that thick piece is the thrust washer. You may have to pry it loose but it will come loose.
flybuddy
Re: Thrust Washer
Thank you much. The othere funky issue was that in torquing the prop nut it recommended 40.7 ft/lbs. To get the cotter pin hole centered I have choice of either 10 or 55 lbs. Do folks play around with the washer thickness to get the torque exact or is it not that critical?
72SideWinderSS
Re: Thrust Washer
I just torque to the recomended spec and if needed, tighten to the next hole.
just my $.02
