Ramman1505
- Joined
- Aug 15, 2021
- 5
Last year I was out on the water for about 30 min no issue. I shut the boat off and we floated for a bit. When I started the boat back up I couldn't get up on plane. The engine would get up to around 2700 rpms, then it felt a few cylinders had dropped out. I noticed when this happened, the tach went up in rpm to about 4800. If I let off the throttle the engine would return to normal running condition along with the tach readout back to 2700. This occurred at the exact same rpm repeatedly, regardless of throttle position. I'm convinced it's a spark issue and not a fuel one, given the behavior of the tach, and the consistency at with rpm it occurs at. I've tried disconnecting the tach, along with bypassing the shift interrupter switch with no luck. It seems to only happen once the engine is warm. My concern is the thunderbolt IV module is going out. There were a handful of instances where if I would floor the boat, it would come out of this misfire state and haul ass like nothing was wrong. The engine behaves perfectly upon deceleration thru the entire throttle and rpm range. The specific issue is some type of spark issue occurring around 2700 rpm, on a warm engine, upon acceleration only. Anyone have any thoughts to what else this may be? Boat is a 1987 Chris Craft Scorpion with the 5.7 Mercruiser and Thunderbolt IV ignition.
