90stingray
- Joined
- Oct 26, 2010
- 1,162
Previous post, if you want to get more up to speed: http://forums.iboats.com/showthread.php?t=447155&highlight=4.3+surge+backfire
Working on 1990 4.3 V6.
Anywho, I still am fighting my surge and backfire around 4000 rpm's. I took her out last weekend and was able to get 4400 rpm before the surge and backfire. Only thing i changed was the gimbal bearing. I guess it was really draggin down on the engine
Opened sending unit up to inspect fuel tank... all is nice and clean. Checked antisiphon valve... all is free. Opened carb back up checked float level and float drop... all is well. So i am running out of ideas.
I checked the timing again... she was still at 8 all warmed up at idle on the muffs. But if i give her some throttle to say 3000... the advance only goes a little ways. Off the timing tab, but i can still see it. Prolly no more than 16 btdc. That seems low to me. Figured these would be in the 26-30 range. Just wondering what exactly controls the advance? Why would it only advance a little? What do i need to check out? Help me out guys. Thanks.
