Thundervolt 4 question
tricone
Hi all hope winterizing is going well...
I was thinking about an engine swap from 87 4.3 to 5.7 gm and was thinking of the variables and i was wonderin if the 6 cyl ignition would work on the v8:confused:
Thanks
Don S
Re: Thundervolt 4 question
Just change the cap, rotor, and ignition module (outside the distributor) for the V8 models.
The sensor inside the distributor is the same, as well as the gear that goes on the cam.
