TI Trailer Help
Dsage
I have a 1989 TI Trailer model C15. I blew out a bearing Sunday night coming home and I can not for the life of me find bearings that will fit. its a tapered spindle some one said the outer is 1 1/16 but they had no clue on the inner or the races. Any one out there have the info I need.......
Re: TI Trailer Help
Ayuh,... Welcome Aboard,.... The bearing races, have Part #s on them,....
If ya can't read the tore up races, pull the other hub, 'n look at those bearings, for the Part #s....
Dsage
Re: TI Trailer Help
I wish it was that easy, the otherside has no part numbers on them. I have taken them to several places and they can not help either. Since TI was bought out by ez loader most of the current dealers have never messes with a TI trailer before.
Re: TI Trailer Help
Ayuh,.... Ya need wheel bearings, not another Trailer,....
Take the pieces ya got, or better yet the bearings outa the other side, to a Bearing Shop, or an Auto Parts house...
They'll be able to match 'em, by part #s, or by Mic'in' 'em for the dimensions...
This ain't Rocket Science,... ya need 2 measurements, the quill diameter, 'n the inside Id of the Hub....
jbetzelb
Re: TI Trailer Help
I went through the same hell 2 years ago. 89 TI trailer. Bearings were fairly easy to match but the inside seals were impossible. I was all over the place trying to match parts for mine. Walked into Sealand Marine Omaha and told mwhat my trailer was and that I needed bearings and seals. They went to the shelf and pulled me a kit and it fit perfectly. SeaLand Marine Omaha. 800-706-8232. Ask for the parts dept. My guess is thay can help you and will work out mailing you a set or tell you wexactly what you need.
Dsage
Re: TI Trailer Help
Thank you jbetzelb, the seals are the main issue I'm having now. I will give them a call, heck I could even drive there if needed Omaha is only 4hrs away from me....
