pitlife4me
- Joined
- Sep 2, 2007
- 10
I bought this boat couple years back as a project boat it hasnt let me down as far as giving me things to do to it. I have a 50hp 2 stroke motor on a bay liner capri. I once had problems with speed and adjusting the trim helped that problem but then found out I had cooling problems because of trash in the Therm. Of course I had to work my way up to that point and replace impeller so on and what ever. This engine never really got that hot but did make a little steam. It has always made a little ticking noice in the back when I gave it the throttle. It doesnt make the noise at idel and when it does make the noise it isnt that loud. I have never taken the boat out far and run it for very long because I dont trust it yet so thats why I think I havent done much damage because of over heating. I guess my question is do all these motors make this ticking noise or do I have a loose lifter or something? It almost acts like a car does when the valves rattle from cheap gas. I know in a car if the motor doesnt get the right oil pressure a lifter will tap but if the lifter is bad it taps even in idle most the time. I have checked around the engine looking for loose parts but didnt find anything other then a loose starter bolt. Also could I not be putting enough oil in the mix? I've been adding 50:1.
