Re: Tighten Prop?
First: Your comment about the pin confuses me. NO large Force ever had a shear pin type prop. Is it a newer Force after say 1990? If it is earlier, the prop has several pieces of hardware that must be on it:
1. thrust washer behind prop
2. prop
3. flare washer OR spacer.
4. Prop nut washer
5. prop nut
If you remove the nut and washer, you will see that the prop shaft protrudes about 1/8 inch farther than the prop hub. This is assuming that the thrust washer is in place behind the prop. If you just tighten the prop nut with the regular washer, the prop will slide forward and backward that 1/8 inch because the regular washer bears against the shaft instead of the prop hub.
There is no danger of losing it though.
You must find a washer about 1/8 inch or slightly thicker with a hole large enough to fit OVER the prop shaft (I THINK it might be 7/8 inch--don't remember exactly) OR, find and replace the FLARE WASHER---it will be a tapered black plastic piece about 4 inched in diameter and 1 inch thick. Problem is that it will NOT fit properly inside the newer style black Semi-Cleaver flared hub prop. It will, however fit inside a stainless Michigan prop. Your Merc dealer should be able to hook you up with a spacer. It has a couple of tits that fit the splines of the shaft.
You also need to double check that the thrust washer is installed behind the prop. If it has broken or is missing, the prop hub will rub on the gearcase wearing it until the splines of the prop hub jam on the prop shaft splines. Not a good situation and MUST be rectified before you continue running. Again, this will allow the prop to move forward and backward on the shaft with the nut properly tightened.
The prop nut only holds the prop on in reverse and need not be killer tight--but not backed off. Snug enough to prevent prop movement and to keep it from backing-off should do it, but be sure it is a self locking Nylock insert nut.
