tiller arm gear 56 johnson 15hp
seawolf
Is there a stop or set screw on the tiller gear (motor side) that prevents the tiller gears from becoming unmeshed? How should I go about setting throttle position beforehand? I don't want to just trial and error, but instead would like to know where the throttle should be in relation to the magneto - timing, so I can then put a stop into place in the gear.
:redface:
