The tiller arm rubs on the top of the transom mount on the 20hp I'm putting together for a friend and it makes steering a pain. I'm making two of these outboards into one good one and both were rubbing in the same spot when I got them. Do you think it would work to put a little aluminum shim under the base of the arm and replace the bolts holding it down with longer ones? I have the powerhead off right now so it's very easily accessible. This seems to be a common problem on these motors, so is there another common fix I don't know about?<br />Thanks,<br />Eric
