Salt Water Junkie
- Joined
- Dec 20, 2011
- 9
I have an '82 Johnson 25hp (j25rcnb) it came as a tiller control, but I want to change it to a steering wheel and remote controll. I have the little brackets to hold the shifter and throttle to the housing. I have the controll box and cables. I have the Teleflex steering helm and cable, I have the steering arm that goes from the steering cable to motor. My problem is , where most outboards I've seen have a hollow "TILT TUBE" for the steering cable to run through and thread on, mine is not hollow. I had made a bracket that mounted to the transom that held the cable and it worked fairly well. But when lifting and lowering the motor it would put a lot of stress on the cable and bracket being that it wasn't on the pivot point of the motor. Can I change just the stern brackets, or do I need to change the swivel bracket too to install a hollow tilt tube on this motor ?
