I have a 1986 35HP Force with a Tiller Handle for steering, on a 16 foot Jon Boat, with a wooden floor and two fishing platforms. With three people, two batteries, a trolling motor, and fishing gear in the boat, it goes about 20 MPH.<br /><br />Under full throttle I can steer the boat to the right, good enough, or at least acceptable enough for me, but if I attempt to turn the tiller handle to the right, which turns the boat to the left, it is extremely hard to do. So much that I back off the throttle, as it feels like I might snap the tiller handle off. I actually start sliding on the seat, trying to steer the goofy thing. <br /><br />I do not have a trim tab, or that little rudder thing on the bottom of the cavitation plate. All I have is a bolted on exhaust snout that isn't adjustable.<br /><br />I did notice that when I get up over half throttle, it appears that my throttle linkage will start to go out of center, at the hole where it goes through the bottom shroud, like the motor is turning on the mounts, and causing it to rub on the cowling, so I have to believe that the prop is causing the leg to turn so hard, it is twisting on it's rubber mounts. <br /><br />Would there be another prop I could go to, that would help with this problem? It seems to me I read something about a Cupped prop helping out hard steering problems to one direction. <br /><br />When I turn the prop over by hand, I do see that one blade looks like it it is closer to the gear housing, or the skeg, then the other two, but I didn't know if that could cause this or not. I didn't want to buy another new prop like I have, and still have the same problem. So I thought I should post here, to see if I should maybe get a cupped prop. Maybe they don't even sell a cupped prop for my engine. Could I have the mod added to a new prop? <br /><br />I'm baffled, and stumped.<br /><br />As always, any, and all help would be greatly appreciated.
