Re: Tilt Adjustment and Tachometer
Or is the formula (or goal) to have Highest cruising speed vs lowest rpm via adjusting trim of the motor?
Thanks!
The goal is to have the highest RPM for a given throttle setting because the engine is designed to work most efficiently at higher RPM, and also to minimize hull drag.
Given a fixed throttle setting, RPM will go up with boat speed, and boat speed will go up with reduced hull drag. Trimming the engine (really the whole boat) finds the lowest hull drag. The highest RPM is therefore your indication that you've found the lowest hull drag.
Seabob4 made a good point of marking your bezel. But remember this may be different for different throttle settings, so you probably only want to make a mark for WOT. Also, weight distribution in your boat (especially a small boat) makes a big difference. If you adjust for just yourself, it will be different for adding a big buddy. A big guy at the back of your boat is like nose-up trim, and a big guy in the bow is like nose-down trim.
Andy
