Marchosia
- Joined
- Jul 18, 2008
- 89
So, ive noticed here recently that when i trim my motor up while fishing, it slowly goes back down, not bad enought that it is bad but it does it.. So today I raised it all the way up like it said an took the plug out an could not see any fluid, so slowly i lowered it down an it got almost all the way down before i could see any..
So my question is, is the fluid causing the motor to slowly go down, an if so how would you go about puting the fluid in, when its all the way up or down. An how do you drain the fluid out... i haven really looked at it much on how to get it out so im sure it would be easy if i looked..
But if its not the fluid what else would cause that problem
Thanks in advance..
Thanks in advance..
