Tilt and ignition problem
dmarque
Today I was out boating and my son accidentlly move the trim up a little, now the trim won't work and neither will the ignition. I have tried changing fuses but I have not solved the problem. Any help would be greatly appreciated.
dmarque
Re: Tilt and ignition problem
My boat is a 93 bass tracker 17pro with a 40hp johnson
dmarque
well I found the problem. I didn't check all the fuses . There is a 20 amp fuse inside the housing of the motor by the seleniod. I just thought I would post it in case anyone else has the same problem. I did find help from this forum though.
