I have a 74 115Hp. It has and add on Tilt and Trim it's a 2 ram system not sure what kind. On the bottom of the cylinder there is a "Tee" So I kinda thought that maybe a factory TNT from the same year but bigger motor would work. replacement parts for a Evinrude 135hp factory Tilt and Trim and of course the part is Obsolete but i'm not even sure if thats the one I need or will any "Tee" work I'm confused. The tee goes to the lower tilt line I think here is some pics
The tee you are looking for may be part number 122497. If so, this Bombardier dealership has 6 new pcs in inventory. Give them a call:
US BOATWORKS INC, 930 OSAGE AVE, KANSAS CITY, KS, 66105-1850 (913) 342-0011
i would go to a NAPA. most autoparts stores will just have a small selection of emergency pre-packaged on a display. NAPA should have a wall rack of drawers and bins with brass brake fittings. The 1970-1989 johnnyrude used 1/8" male pipe threads, brass adapters, and SS brake tubes. Same stuff as your average buick except in brass, aluminum, or SS. (your trim system was actually engineered by a detroit automotive oem contractor).
