I've notice my 2006 Suzuki DF140 does not tilt up as far as it used to, it used to tilt up so the the prop completely cleared the water, now it won't. No other issues with the tilt or trim.
Could this just be that I am low on fluid? If yes, is this normal for a 4 year old motor or do I have a leak that needs attention?
When checking the fluid level, do I have to open the manual valve and hoist the motor the last foot or so before opening the reservoir or can I check it in the highest position it gets now? I don't want to lose any more fluid just to check if its low or not.
Lastly, is automatic transmission fluid OK?, I've seen a lot info in searching the forum.
Thanks in advance.
Thanks in advance.
