The engine is a 1968 Mercruiser straight 6 cyl 160. The out-drive a type one pre-alpha ser#C2125004A. Both look to be original to the boat. The lift cylinders on it have two hydraulic lines each to them. The dash mounted tilt and trim switch control has three buttons. The two wires at the gimbal were in such bad condition when the boat was purchased I could not tell what the correct wiring should be with this setup. With two styles of switches listed in the parts manual, what is the difference in the switches. Both are two wire switches. There is a #39672A1 and a #45942A1. I have been told that one style is NORMALLY OPEN and one style is NORMALLY CLOSED. Is this true and witch is witch? The switch is to stop the up travel on the outdrive. Thanks for a reply
