I have a 1991 Evinrude 48 hp special with a single cylinder tilt and trim. I took out the fill plug and added oil as I raised the motor until if was all the way up. Put the fill plug back in and the motor stayed up just fine, no leak down.
I ran the motor down just fine but it sat there and leaked all the oil out thru the shaft at the top of the cylinder.
Is this seals in the cylinder or something in the pump?
