Re: Tilt and Trim not working on 2000 Merc 200HP
I just had this problem with my 2005 Merc 90. My pump motor is on the outboard bracket Im not sure if yours is but, I could hear the relays clicking but nothing was happing. I took the Pump motor off and found water intrusion, it was all corroded. I replaced it and it works fine. On a side note dont go cheep on the motor. I did and in 6 months I was replacing again for the same thing. Water leaked in where the wires go in to the pump motor. The only after market pump motor I trust now Is by Arco($250) they are less expensive than the mercury one($480) but built to the same standards. Hope this helps.
