tilt and trim not working
poppyskayla
mercury 40 oil injected 1989 when you hit the up/down switch it clicks the solenoid but no action, went straight from the battery to the tilt/trim still nothing swaped solenoids still same problem <br />thanks in advance
RICKRICK1
Ensign
Re: tilt and trim not working
poppyskayla,<br /><br />Have you checked all of you electrical connections, pay extra attention to all of the grounds. Clean and brush all connections even if they look clean, also check for broken wires and corroded wires. Does it do this both directions?<br /><br />Hope this helps.
Hooty
When you say you straight went from the battery to the t/t, do you mean to the pump?<br /><br />c/6<br /><br />Hooty
RICKRICK1
Ensign
poppyskayla,<br /><br />Have you checked all of the electrical connections, pay extra attention to all of the grounds. Clean and brush all connections even if they look clean, also check for broken wires and corroded wires. Does it do this both directions?<br /><br />Hope this helps.
trimmer21
us jumper wires could have a broken or corr, wire you can not see
