tilt and trim problem on evinrude moter
ibgood
i have a 1985 110hp Evinrude. the tilt seems to be working fine, but the trim will not adjust while the motor is pushing the boat along. i checked the fluid level and it is full with no visible leaks. any ideas what the problem might be? thanks in advance.
evinrudeman
Re: tilt and trim problem on evinrude moter
Do you hear the pump run? If not, clean ALL the contacts in tilt trim junction box. I used emery cloth.
