sailingMel
- Joined
- Aug 22, 2010
- 18
I have a 1997 Mercruiser 3 liter. The trim is in the up position and will not go down. The pump tries to work in the up position but only clicks when I try to let it down. I hate to start just replacing parts so I ask, does anyone know enough about the trim to give advice on how to test the selnoids or could there be another reason it's not working?
Also there is a small tank on the side of the engine that says grea case lube...what fluid does that tank need?
Thanks in advance for any input...Mel
