I have a 1985 Johnson 115 Outboad motor on a Procraft Bass Boat. The boat<br />and motor have been sitting for a couple years (in storage) and I proceeded<br />to clean it up and get it running recently. After rebuilding the carb, and<br />lubing everything, she started up and ran great. Even had her out for 3<br />outings in one week. Just this past week I tried to launch her and found<br />that neither the tilt or trim would go up (out). After fiddling with it for<br />awhile and since I could not get the motor off the transit saver, I took her<br />home.<br />At home I loosend the manual release valve and I could pick the motor up off<br />the T-saver and bring the tilt piston in. Note: If I tighten the manual<br />release valve while motor is down, I cannot begin to budge the engine up,<br />although if I hold the engine up by hand and tighten the manual release<br />valve, it will not hold the engine up.<br /><br />After studying the hydraulic diagram that came with manual I purchased<br />awhile back, I took the Tilt and Trim unit out and found that the tilt<br />cylider will retract under power, but will not advance. I pulled the motor<br />out, it runs in both directions. I replaced the tilt/trim relief valve, to no avail. I am at the point, that at looking at the hydraulic diagram, there<br />could be a number of thing that cause this problem. What I need is some<br />sound advice as to how to narrow the possibilties. I would appreciate any<br />suggestions at this time.
