I have a 1985 Johnson 115 Outboad motor on a Procraft Bass Boat. Neither the tilt or trim would go up (out). I can loosen the manual release valve and can pick the motor up off<br />the T-saver and I can force the tilt piston in. Note: If I tighten the manual<br />release valve while motor is down, I cannot begin to budge the engine up,<br />although if I hold the engine up by hand and tighten the manual release<br />valve, it will not hold the engine up.<br /><br />After studying the hydraulic diagram that came with manual, I took the Tilt and Trim unit out and found that the tilt<br />cylider will retract under power, but will not advance. I pulled the motor<br />out, it does
runs in both directions. I replaced the tilt/trim relief valve, to no avail. I am at the point, that at looking at the hydraulic diagram, there<br />could be a number of thing that cause this problem. What I need is some<br />sound advice as to how to narrow the possibilties. I would appreciate any<br />suggestions at this time.
