tilt and trim wiring
gholems
Hello All,
This is my first time here and not shure if I am posting in the right spot. Anyway I am new to boating and have a couple of issues. I bought a boat that needed repair purpasly so I can learn the ins and outs. I am sorta stuck so I thought of posting here. The tilt & trim wires were all cut on the johnson 1985 v4 90 HP I bought for the boat. There are 7 wires that are sitting there at one point were connected to something. I have checked most of the wiring diagrams for clymer and seloc but came up empty. The blue and the green to the right are to the tilt motor. The other wires run to the tilt relays. Also the control box that came with the motor had match wires as on the left(red&w blue&white gree&white). The two wired in the middle Blue and Green I have no clue. I want to be able to use the trim and tilt on the new shifter I will be purchesing.
Thanks
gholems
Re: tilt and trim wiring
figured it out. A switch was installed at one point so they could lift the outboard to put on trailer and they cut it out.
thanks
