Re: Tilt Cylinder Leaking Force 125
rams push in both directions depending which end fluid is being pumped into.
the system lasts a lot longer if you let off the pressure. down pressure is always less than up due to gravity. best way to release pressure is to lift engine, install transom saver blocks, let engine down onto blocking.
mercury does not sell all seals. if the leak is from your tilt head then mercury does not offer the parts needed to do a proper fix. go to ebay and look for a non-mercury kit that includes both lower and upper tilt shaft seals.
hopefully it is just your fitting. they go bad from salt water. go to NAPA and find brake fitting #1441. It will replace the original. Be very careful not to damage threads in band collar.
