Re: tilt fluid
airwarrior,<br /><br />I have combined your two topics since they ask basically the same questions.<br /><br /><br />I have a 73 Boston Whaler, with the origional 73 Johnson 85 hp engine. It has a tilt unit on it, and it seems to lose pressure. You can tilt the motor up, and in a couple of minutes it has bled down/lowered itself. As you can imagine this isn't good. I looked for leaking fluid, and don't see any, the ram (guess that is what it is called) looks a little moist, so maybe that seal has leak enough over the years that I need to refil the resivour, but I can figure out where or how to fill that, and what type of fluid do I use?<br /><br />Thanks for the help! <br />--------------------------------------------------------------------------------<br />Posts: 5 | From: Houston | Registered: Nov 2005 | IP: Logged | <br /> <br />DJ <br />Supreme Mariner <br />Member # 5471 <br /><br /> posted December 02, 2005 04:06 PM <br />--------------------------------------------------------------------------------<br />The OMC titl/trim unit for that year was a one year only item, as I recall. It worked OK, but was rare.<br /><br />OMC makes a tilt/trim fluid. Check with your John/Rude dealer.<br /><br />Be aware that there is a manual bleed down screw on the side of the unit. It is recessed and hard to see. Make sure it is snug, DO NOT overtighten.<br /><br />As I recall, there is a fill/check hole on the side of the motor.<br /><br />--------------------<br />If you keep doing what you've been doing-you're going to keep getting what you've got.<br /><br />--------------------------------------------------------------------------------<br />Posts: 11986 | Registered: Dec 2001 | IP: Logged | <br /> <br />airwarrior <br />Cadet <br />Member # 68403 <br /><br /> posted December 02, 2005 04:19 PM <br />--------------------------------------------------------------------------------<br />Thanks Dj! I'll give it a look. It is tilt only, not trim (rather odd?).<br /><br />What does the manual bleed down screw do exactly? Is that incase your motor gets stuck in the up postition, you can relieve the pressure or something to let it down??<br /><br />I saw the word Prestolite on it, could it be some aftermarket unti that was added?
