Just got back from Kokenee Salmon fishing and noticed a problem this morning. Outdrive would not go up to get the ram supports off. I had to hand lift it to get them off. When I was done fishing, lifted the outdrive and it would only go about half way and stopped. Had to lift it assisted by hand to get it all the way up to put the supports on. Got home and took the ram supports off and the outdrive started to go down half way and stop. There is no fluid leakage anywhere and I just bleed the system last weekend after our trip. I also replaced the the hydraulic lines last months and worked fine. No air/no fluid leaks? Anyone have an idea? Tilt motor rebuild? Thanks all.
