tilt limit switch
guido469
I have a 1985 merc. 50hp with T/T, and was wondering if the T/T would work if the tilt limit switch is not hooked up. I bought this motor and have found nothing but things wrong. This is just the latest. If it wount work with it disconnected can someone steer me in the direction to find a new one. thanks in advance.
monk-monk
Re: tilt limit switch
Yes guido that trim limit switch will keep the pump from running if the switch is defective. Find where the limit switch plugs into your wiring harness, unplug it and install a jumper wire to connect the two wires in your wiring harness where the switch used to plug in...this jumper wire will by-pass the switch and it should work. If not then the prob is elsewhere.
guido469
thanks. my trim wireing has four wires-blue,and green to the plug.blue out of the plug to trim limit.purple to trim limit. and brown with an eye. wheres the brown with the eye go? pump selenoid maybe?
monk-monk
Hey Rip, follow your wires from the limit switch to your boat wiring harness. The limit switch should plug into the blue and the purple wire from your harness, put a jumper wire to connect the blue and purple wires from your main wiring harness. The brown wire you're speaking of may or may not have been used...my Merc manual shows a brown wire that is used to operate a trim POSITION GAUGE...if the boat came with a trim position gauge, which most all outboards do not have simply because you can visually see the position of an outboard from the Helm whereas you cannot if you have an outdrive with an inboard engine.
monk-monk
Guido, i apologize...this reply was for you but i was also trying to help Rip and used the wrong user name when addressing your question...
