Can anyone please tell me the correct name for the pin that adjusts the tilt angle of engine? my engine had a piece of mild steel threaded rod about 101/2 inches long with nuts both sides which were rusted solid,I have cut this bolt out as I will need to adjust the engine tilt angle after several trials, I have seen this pin on other engines and think it is fitted with a fitting called an ANTILUCE on one side only, other side is solid, ie pin can only slide out one way? any help please, JBD.
