Tilt pin
beneteau
What is commonly used for a tilt pin? I've searched the net for tilt pin, thrust rod, thrust support----you name it----I've tried it and found nothing?
Any suggestions?
Thanks...................
xtraham
Re: Tilt pin
what engine year/make ? if you are looking for the pin you move from hole to hole, it's the thrust rod
beneteau
Re: Tilt pin
1989 Force 50hp. Yes, the pin you move from hole-to-hole.
About 10" length, 3/8" or so diameter, with hole for retainer (cotter pin, etc.
Thanks.......Lee
Plainsman
Re: Tilt pin
Called a tilt pin here.
tashasdaddy
Re: Tilt pin
i may have one, just parted out a 89 50 hp force. let me check.
beneteau
Re: Tilt pin
xtraham:
Checked your suggested website for my model Force and found this diagram:
As near as I can tell, #32 is referred to as a lockbar w/handle. #33 is a spring pin and #35 is the lockbar handle.
If those are the parts, all about $30.00. A galvanized or stainless pin with end retainers would accomplish the same thing.
tashasdaddy
Re: Tilt pin
thought i had one, must have kicked it too many time on the shed floor, and threw it out. a long bolt and locking nut would do the same thing.
beneteau
Re: Tilt pin
Lord tashasdaddy, don't throw anything away. You'd be amazed the things that sell on eBay and some of the prices some items get.
I'm an ex-ham radio operator. Carried around for about 20-25 years---old resisters, capacitors, old radio knobs, tube sockets, you name it. All stored in an old foot locker. After my last move, I thought about throwing all that mess away; but, decided to put them on eBay. Sold all of it!
I'll keep looking around for some type of pin. I'm feel sure they're still being used probably on smaller motors.
rickdb1boat
Re: Tilt pin
Home depot, Long carriage bolt, drill 1/8" hole in threaded end and insert hitch pin, Done....
tashasdaddy
Re: Tilt pin
i sell most of my junk on ebay also. thats where i parted out the 50 force. power head to one lower to another. mid section and cowl when to the street connected together, lasted about an hour, and some one picked it up.
