The problem started with hitting the tilt switch and nothing happening. Keep hitting the switch and it would work. It got worse over time and now wont work at all. This motor also has a tilt switch on it. Neither works now. I took off the cover and can hear the solenoids click when the switch is pressed. There are 2 solenoids 1 for up and 1 for down. Each clicks when the appropriate button is pressed. I can see 2 wires coming out of the bottom of the top end and going down into the mount. I don't see anything wrong with the wires. The motor is down. I cant figure how to raise it. The only lever I see on the mount seems to be a lock out to keep the motor up once it has been raised. I cant see the tilt motor at all with the motor down. I'm stuck and don't know what to do from here. The switches work and it seems unlikely that both solenoids are bad. Any suggestions?
