Re: Tilt Problem
Bare with me here. i just ordered a chilton manuel on the engine and outdrive. is the clutch at the end of the screw drive ? if so, i took those 4 bolts loose and the cover wouldnt come off, so i checked the oil and it was real light cream colored ! looks light water has been in there for awhile. how do i remove the clutch plate ? also the tilt pins, i think what your talking about i removed those 2 covers all i saw was rust ! no grease at all ! are the tilt pins where the 2 rubbers are to stop the outdrive going down ? also, theres kind of a small crack between the rubbers and the covers of the tilt pin covers, like its bound up and pushing out on the covers ! the covers on the clutch plate and the tilt pins, should they be sealed with something just like you would an oil pan ? what kind of grease for the tilt pins ? and what kind of oil for the clutch plate, upper unit, lower unit should i use ?... Thanks everyone for all the help, I'm realy getting somewhere finally ! I'll get the boat manuel today and will understand these ares your talking about. THANKS AGAIN ~
