jayfarmlaw
- Joined
- Sep 24, 2005
- 21
I have a 97 VIP w/ mercruiser 4cyl. I have had a water in tilt oil problem that I think I have traced to the vent hole in the top of the cap. The tilt anf trim has always been fine but this year the trim pump comes on like it should but the lift is usually very slow to not at all.......then sometimes it works fine.
Down seems to work fine.
You can lift the unit by hand and it is hard but will come up with my help and someone on the switch.
Battery is new. 30 wt oil is stilla little milky after 4 changes.
Tomorrow I will tear into the pump unit for a good cleaning. Anything I should look for specifically? What are your thoughts on the problem?
Thanks in advance for your response.
Jay
Jay
