Tilt quit this weekend, need suggestions
LouSylvia
I have a suzuki 115 HP and this weekend the tilt quit, this is the story. I was getting ready to go to the river and was running the engine warm it before hitting the ramp. When I turned the engine off and hit the tilt button to raise it for the trip, nothing. I grabbed the lower unit and pulled it up halfway, the button then worked and the motor came all the way up under power. I arrive at the ramp and the engine will not lower. All I get is click,click,click on the engine. I know the battery is good(1 week old). I have looked in the manual and still have no clue. Some one please guide me in the right direction. I hate to take it to the mech because I know that in addition to whatever is wrong, I will probably receive more work that is not exactly needed. Thanks guys.
michaelb
Re: Tilt quit this weekend, need suggestions
I had a similar problem on one of my Merc 175s. Turned out the two wires going to the lift motor from the switch were terribly corroded – even 4 or 5 inches under the insulation from the end. I removed the lift motor and replaced the wires. After the lift motor was reinstalled, it worked great and has been ever since. Symptoms sound similar.<br /><br />Hope this helps. <br /><br />Take care, Michaelb
