I was out on the water last year and pulled the motor up to clear some weeds from the prop when this happened:
Thankfully I got it locked in the down position and was able to use it the rest of the summer without messing with it. I want to correct it now though because not all ramps will be forgiving of launching in the down position.
I took another picture that has the other side of the mechanism:
I have a cable wench that will hold the motor up if I pull it. But I figured I should ask here first because there may be a way to fish this out and fix it without pulling the whole thing and if I DO have to pull it, I'd like to know the best way to go about it.
I have the clymer book for my motor but in the tilt/trim section its primarily dealing with hydraulic tilts and not manual tilts. And in the install/removal portion it just says "Remove motor from boat."
Thanks in advance for the help. I'm running a '74 Johnson 85hp if that helps.
