jbuote
- Joined
- Aug 17, 2016
- 1,001
I'm wondering what the consensus might be... (if one can be had..
Turns out my description below is longer than I thought.. Trying to give backstory to it..
The ;TLDR of it is:
When you go out in local lakes (fresh water) for some fishing, and you get to the spot you're going to fish.. Do you trim your engine up out of the water?
Read on if you want the backstory.. lol...
I'm asking because I ran into an issue today while out fishing with the Admiral..
We got to the lake for our second outing in our new to us boat with a J115TLEOR on it..
Engine ran fine as usual.. We get to the first spot.. Drop trolling motor, raise outboard.. It can get quite shallow so I tend to raise the outboard as a precaution so I don't it anything with it..
We fish for a bit, raise trolling, lower engine, and cruise to next spot.. Repeat dropping trolling, raise engine..
We fish and do all that again on the the next spot.. etc...
Several hours later, and the last spot of the day... Drop trolling, raise engine... Fish...
We go to leave back to the ramp, and tilt isn't working... Wont' run off the switch on dash (remote doesn't have built in trim switch, so it's on the dash..) nor will it work by using the up/down buttons on the engine..
Wouldn't even attempt to go up or down.. No clicks, no humming of motor trying, no nothing...
At this point, I'm thinking I blew a fuse, but couldn't get the cowling off.. It tilts up pretty high and wasn't room to get to the front latch..
Engine battery is fine... Fish Finder works, bilge pump works, but trim doesn't. Same battery.. Didn't even try to start it obviously, since lower unit is tilted out of the water at this point..
Had I left it tilted down, I could have tried to start it (unless main inline fuse kills power to TNT and starter) and maybe used it.. But it was stuck tilted up.. Wasn't even going to try... LOL
So, our new to us trolling motor (On it's new dedicated battery, not main engine battery) got a workout and was great!! It trolled us about 30 minutes at max speed (for a 50# 12V) all the way back to the ramp..
Now I know I won't be trimming/tilting up so far I can't get the cowling off anymore... I've never had TNT before this engine..
Makes me wonder also if a limit switch is missing and/or not functioning properly/adjusted properly... Hmmm...
I'm going to go through and double check things... I'll make sure connections are shiny clean and could eat off of them....
Make sure switches are good etc... Did that before, but will check again..
If it's a fuse as I suspect, I'll try to pin down what made it blow a fuse in the first place..
Sorry for the whole novella here, and not asking repair advice.. (yet.. haha!) Just giving backstory to the real question which really is...
Do you trim your engine up or not when you're fishing?
This is a new area for me, so I'm looking to learn from you folks as to best practice here.. If what I was doing wasn't good..
Thanks for reading!!
The ;TLDR of it is:
