Well hello all. I have my first question of the year as I am trying to get an early start before the season begins. Here is my problem, last year at the end of the season everything worked fine, now this year I have 2 fresh batteries and the tilt/trim motor does not work. It worked the klast day i used it before seasons end. All I hear are the 2 relays in the back clicking when I push the up/down switch and thats it. I pulled off the cover for the relay pack and everything looked fine. I disconnect the connector that comes out of the box (green and blue wires) and metered them coming out of the relay while the switch was being pressed. Voltage was good in both directions. On the motor side of the connector I tried applying direct voltage to see if I can hear the motor turn or at least click and nada. Is it possable for the motor to die just from sitting out a winter? Just dosent make sense. I checked the wires and did not find any fusable links unless there is one sitting in the sleeve that travels under the hood?
On top of that I need to replase the prop shaft seals along with a few otheres as some water was getting in the lower unit last year. Does anyone know where I can get that special puller from to pull that metal piece out that is holding the shaft and seals together?
Thank you for all of your help.
Jeremy
Jeremy
