Tilt Trim advice
crazeynine
Just bought a 74 pro line 17' boat with a 76 Johnson 115 outboard. One of the tilt cylinders is broken. I do not have the manual yet, so I am not sure what the correct terms of the parts are, 1st boat. There is a cylinder on the left, if behind boat looking at motor, with a wire connected to it with what resembles a grease fitting, that is broken off, leaks hydraulic fluid. Can I have that fixed, drilled out and replaced, or do I need to find another cyliner and replace?
